Hi… I read a post about sticky column on https://tagdiv.com/multiple-sticky-sidebars/ and I try it, doesn’t work.
I don’t use smart sidebar because of Adsense. Can I use those sticky column without activing smart sidebar https://prnt.sc/k4z5vp? Here is my blog https://irfan.id.
Thanks,
The option in the theme panel you are referring to has to be active, it it’s not the sticky settings will not work. That was the case before the new option was introduced, the general smart sidebar option has to be active.
Maybe this functionality will change in the future, but for the moment that is the case.
