How to use "tagDiv Speed Booster" plugin
How I can use the Speed Booster plugin to load the website fast.
a) turn it on
b) read the docs (right side of page); if you need to further optimize.
For most folks just turning it on will do all you need.
May not work with certain things which also rewrite pages (e.g., move things from top to bottom of page)
Thanks @Chris for the answer in advance!
@varunrupal
the speed booster plugin was designed to increase the website loading speed by moving the css and js files to the bottom of the page, as it’s explained here: https://forum.tagdiv.com/page-speed-guide/ Notice that some plugins may cause issues when you try to move their resources at the page bottom and to avoid conflicts we created a list with plugins that work fine with Speed Booster and if you add a plugin that is not on that list
the Speed Booster will disable automatically.
