Hi i was wondering if i could make it so the subtitles to articles get shown below the article title using “block 9”. As it is this is the only thing i see. My website is hosted at cronachedellecalabrie.it but it’s currently under maintenance so i can’t have you view it unless you provide an ip.
<br>
<i>Above is the “block 9” thing i mentioned, by linking it to a post category and dragging it onto a page i can get it to show article titles, i was wondering if it could display article subtitles along with those.</i>
<br>
<i>This is the block as viewed by the user. As you can see the article titles get displayed but the subtitles don’t</i>
<br>
<i>The article subtitle is added to the article through this text box at the bottom of the page upon creating a new article. I was wondering if i could get this very piece of text to show using “block 9″</i>
Hello twindrills,
Unfortunately, our theme does not have any such an option that allows you to display the subtitle on blocks, sorry! Please notice that is not a simple task and if you want to do that, you will have to edit the core files in order to achieve as you wish. As a hint, you will have to edit the td_module.php core file like this -> http://screencast.com/t/mv6bzuS43
If you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
