Https only site – related posts plugin issues with images
we try to enable SSL on our website with Newspaper theme. The only warning we have is with images (post’s thumb) of the related posts plugin which are sourced as http. It’s like this plugin does not use relative path?
Thx
To be more precise, the first tab “related posts” load images properly but the 2nd, ajax loaded (“more post from this author”) posts list has http issues (thumb images are source through http)
Our theme has ssl support and there should be no issues in moving to https.
Please make sure you follow this guide to move your site over to https: http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
We have not tested any plugins that make this transition automatically so we cannot say for sure if the process gets done properly.
we followed that kind of process to move the entire site to https.
If you check a random page like https://www.aerospatium.info/un-marche-en-plein-essor-mais-plein-dincertitudes/ you will see that:
– on page load, there is no http warning (every ressources are properly linked)
– if you click bottom on “Plus de l’auteur”, the articles thumb will be ajax loaded and include with src as http (and thus security warning)
Thanks a lot for your time.
Note…
be sure you did a search/replace in your dbase for any images “inside posts” which have http:://yuorsite/image.jpg type links. Make sure you added the explicit https path to your site in the wp-config.php file.
Do a full regenerate images run.
For instance, if you have an image in a post as http://yoursite/image.jpg and then a new related thumb is rendered in certain places, you may end up with http://yoursite/image-thumn.jpg
Make sure you have a full 301 redirect in place for *all* requests for http to redirect to https in your htaccess file at the TOP.
We went thorugh this nov. 20144 with our site. All of the above were needed.
sorry for the delay to answer.
There is no http hardcoded link into the database. Our Apache virtualhost is configured to force https.
WP_HOME and WP_URL are defined with https.
The only problem comes from the theme functions and plugins which in that case generate image html code with http protocol.
For example, on that page: https://www.aerospatium.info/ses-9-sera-lance-le-24-fevrier/ when you click on “PLUS DE L’AUTEUR” at the bottom, Ajax request is:
POST URL:
server answer:
{"td_data":"<div class=\"td-related-row\"><div class=\"td-related-span4\"> <div class=\"td_module_related_posts
td-animation-stack td_mod_related_posts\"> <div class=\"td-module-image\"> <div class=\"td-module-thumb
\"><a href=\"https:\/\/www.aerospatium.info\/linde-lancera-lorbiteur-martien-emirats\/\" rel=\"bookmark
\" title=\"L’Inde lancera l’orbiteur martien des \u00c9mirats\"><img width=\"218\" height
=\"150\" class=\"entry-thumb\" src=\"http:\/\/www.aerospatium.info\/wp-content\/uploads\/2016\/02\/Satalite_Double0000-218x150
.jpg\" alt=\"\" title=\"L’Inde lancera l’orbiteur martien des \u00c9mirats\"\/><\/a><\/div
> <\/div> <div class=\"item-details\"> <h3 class=\"entry-title td-module-title\"><a href=\"https:\/\
/www.aerospatium.info\/linde-lancera-lorbiteur-martien-emirats\/\" rel=\"bookmark\" title=\"L’Inde
lancera l’orbiteur martien des \u00c9mirats\">L’Inde lancera l’orbiteur martien des
\u00c9mirats<\/a><\/h3> <\/div> <\/div> <\/div> <!-- .\/td-related-span4 --><div class=\"td-related-span4
\"> <div class=\"td_module_related_posts td-animation-stack td_mod_related_posts\"> <div class=\"td-module-image
\"> <div class=\"td-module-thumb\"><a href=\"https:\/\/www.aerospatium.info\/ula-lance-un-satellite-radar-du-nro
\/\" rel=\"bookmark\" title=\"ULA lance un satellite radar du NRO\"><img width=\"218\" height=\"150\"
class=\"entry-thumb\" src=\"http:\/\/www.aerospatium.info\/wp-content\/uploads\/2016\/02\/div_nrol45_l1210201614726PM63-218x150
.jpg\" alt=\"\" title=\"ULA lance un satellite radar du NRO\"\/><\/a><\/div> <\/div> <div class=\"item-details
\"> <h3 class=\"entry-title td-module-title\"><a href=\"https:\/\/www.aerospatium.info\/ula-lance-un-satellite-radar-du-nro
\/\" rel=\"bookmark\" title=\"ULA lance un satellite radar du NRO\">ULA lance un satellite radar du NRO
<\/a><\/h3> <\/div> <\/div> <\/div> <!-- .\/td-related-span4 --><div class=\"td-related-span4\"> <div
\"> <div class=\"td-module-thumb\"><a href=\"https:\/\/www.aerospatium.info\/viasat-revise-avenir-arianespace-boeing
\/\" rel=\"bookmark\" title=\"Viasat r\u00e9vise son avenir avec Arianespace et Boeing\"><img width=
\"218\" height=\"150\" class=\"entry-thumb\" src=\"http:\/\/www.aerospatium.info\/wp-content\/uploads
\/2016\/02\/01pr_01507_hirez-e1455107389976-218x150.jpg\" alt=\"\" title=\"Viasat r\u00e9vise son avenir
avec Arianespace et Boeing\"\/><\/a><\/div> <\/div> <div class=\"item-details\"> <h3 class=\"entry-title
td-module-title\"><a href=\"https:\/\/www.aerospatium.info\/viasat-revise-avenir-arianespace-boeing
\/\" rel=\"bookmark\" title=\"Viasat r\u00e9vise son avenir avec Arianespace et Boeing\">Viasat r\u00e9vise
son avenir avec Arianespace et Boeing<\/a><\/h3> <\/div> <\/div> <\/div> <!-- .\/td-related-span4 --
><\/div><!--.\/row-fluid--><div class=\"td-related-row\"><div class=\"td-related-span4\"> <div class
=\"td_module_related_posts td-animation-stack td_mod_related_posts\"> <div class=\"td-module-image\"
> <div class=\"td-module-thumb\"><a href=\"https:\/\/www.aerospatium.info\/la-russie-lance\/\" rel=\"bookmark
\" title=\"La Russie reprend les lancements Glonass\"><img width=\"218\" height=\"150\" class=\"entry-thumb
\" src=\"http:\/\/www.aerospatium.info\/wp-content\/uploads\/2016\/02\/DSC_6666-218x150.jpg\" alt=\"
\" title=\"La Russie reprend les lancements Glonass\"\/><\/a><\/div> <\/div> <div class=\"item-details
\"> <h3 class=\"entry-title td-module-title\"><a href=\"https:\/\/www.aerospatium.info\/la-russie-lance
\/\" rel=\"bookmark\" title=\"La Russie reprend les lancements Glonass\">La Russie reprend les lancements
Glonass<\/a><\/h3> <\/div> <\/div> <\/div> <!-- .\/td-related-span4 --><div class=\"td-related-span4
\"> <div class=\"td-module-thumb\"><a href=\"https:\/\/www.aerospatium.info\/coree-nord-demontre-capacite-orbitale-balistique
\/\" rel=\"bookmark\" title=\"La Cor\u00e9e du Nord d\u00e9montre sa capacit\u00e9 orbitale (et balistique
)\"><img width=\"218\" height=\"150\" class=\"entry-thumb\" src=\"http:\/\/www.aerospatium.info\/wp-content
\/uploads\/2016\/02\/Decollage-KWS4-218x150.jpg\" alt=\"\" title=\"La Cor\u00e9e du Nord d\u00e9montre
sa capacit\u00e9 orbitale (et balistique)\"\/><\/a><\/div> <\/div> <div class=\"item-details\"> <h3
class=\"entry-title td-module-title\"><a href=\"https:\/\/www.aerospatium.info\/coree-nord-demontre-capacite-orbitale-balistique
)\">La Cor\u00e9e du Nord d\u00e9montre sa capacit\u00e9 orbitale (et balistique)<\/a><\/h3> <\/div>
<\/div> <\/div> <!-- .\/td-related-span4 --><div class=\"td-related-span4\"> <div class=\"td_module_related_posts
\"><a href=\"https:\/\/www.aerospatium.info\/dernier-gps-2f-orbite\/\" rel=\"bookmark\" title=\"Le dernier
GPS-2F est sur orbite\"><img width=\"218\" height=\"150\" class=\"entry-thumb\" src=\"http:\/\/www.aerospatium
.info\/wp-content\/uploads\/2016\/02\/GPS-2F12-Lancement_ULA-218x150.jpg\" alt=\"\" title=\"Le dernier
GPS-2F est sur orbite\"\/><\/a><\/div> <\/div> <div class=\"item-details\"> <h3 class=\"entry-title
td-module-title\"><a href=\"https:\/\/www.aerospatium.info\/dernier-gps-2f-orbite\/\" rel=\"bookmark
\" title=\"Le dernier GPS-2F est sur orbite\">Le dernier GPS-2F est sur orbite<\/a><\/h3> <\/div> <\
/div> <\/div> <!-- .\/td-related-span4 --><\/div><!--.\/row-fluid-->","td_block_id":"td_uid_1_56c331ce886e2"
,"td_hide_prev":true,"td_hide_next":false}
as you can see, a href are https but img src are http.
Regards
  • This reply was modified 10 years by gaby.
Weird. Page loads for me as fully https in Chrome/Win10 with no images loaded via http.
But you are correct when you click the link, the ajax loads the additional info as http vs https and throws error.
Also, you have missing font issue on the page, as a console error, it looks like from initial page load.
Hi Chris,
you’re definitely right for the font https://forum.tagdiv.com/topic/wp-booster-error-with-custom-fonts/ 😉
Regards
@gaby I’ve replied you via email!
