I’ve just checked if my site is fully HTTPS and as a matter of fact, it not.
I’ve found some insecure URLs that are from the theme and the plugins. http://www.screencast.com/t/BDNITBCa
Do you have some suggestions on how to rectify these errors? Isn’t the theme suppose to come already with HTTPS?
Thank you
After installing SSL you must change your site URL and WordPress URL to https version
Refer: https://www.infophilic.com/resolve-mixed-content-warning/
Hi Amit,
N
Thank you for the reply.
I’ve already switched my site URL and WP URL to HTTPS version. All my posts and page are secure, but the VC plugin, TAG Div plugin, and the whole theme didn’t change to HTTPS.
Hello Daniela,
We have no reports of this issue for the moment. It must be something local affecting it.
Please check to see if the implementation is done correctly:
http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
https://css-tricks.com/moving-to-https-on-wordpress/
https://yoast.com/dev-blog/move-website-https-ssl/
https://forum.tagdiv.com/topic/moving-to-ssl/
If everything is in order, try it without plugins as there could be a plugin conflict affecting it. Disable all plugins except the page builder, clear cache and reset CDN files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functioning of the theme.
