HUGE problem after update
I’ve updated the theme, but now, the theme panel refuses to work. It has been horrible alltogether. I have followed yours and Chris’s how-tos but none of them helped.
This is what I get when I click on “Categories” under “Layout settings”
td_api_base: td_category_walker_panel is not set. A component with the id td_category_walker_panel is missing. This can be due to an older plugin.
/home/androidportal/public_html/wp-content/themes/androidportalv2/includes/wp_booster/td_wp_booster_functions.php
Missing parameter: ‘file’
/home/androidportal/public_html/wp-content/themes/androidportalv2/includes/wp_booster/td_autoload_classes.php
http://puu.sh/gILdu/304dc811f8.png
When I click on anything underneath that, it stays blank. I cannot, therefore, access custom CSS or anything else.
I have done a fresh install of everything, switched the theme to 2015, installed all plugins, but nothing seems to work.
I would really appreciate if you take a look – androidportal.sk
Thanks,
Lukas
I had to revert back to v1.4 which works great, but i’ve spent 3 hours trying to work it out. Needless to say, I am quite disappointed in how the update process doesn’t work :-/
Hi @Lukas and sorry for all the issues. You have tried with the latest theme pack? We have fixed some issue quickly. We will investigate your issue according with the details provided.
Yes, I have downloaded and then redownloaded the latest theme pack, tried using newsmag as a name for the theme, tried using our typical folder name, even a child theme, but nothing helped.
When I downgraded back to 1.4, everything was back in normal.
I have the same problem, custom setting template not working.
/data/web/virtuals/94681/virtual/www/domains/aloefest.cz/wp-content/themes/Newsmag/includes/wp_booster/td_wp_booster_functions.php
/data/web/virtuals/94681/virtual/www/domains/aloefest.cz/wp-content/themes/Newsmag/includes/wp_booster/td_autoload_classes.php
Fatal error: Class ‘td_category_walker_panel’ not found in /data/web/virtuals/94681/virtual/www/domains/aloefest.cz/wp-content/themes/Newsmag/includes/wp_booster/wp-admin/panel/views/td_panel_categories.php on line 313
The issue seems to come from line breaking – end of line special characters interpretation. Try to replace (overwrite it) the td_panel_categories.php file – http://screencast.com/t/rnRNRNL1Ri with the one provided in the following link – https://www.dropbox.com/s/tegdpkwb43z9air/td_panel_categories.zip?dl=0
Thank you, Emil G.
Hi Emil,
I will give it a go. Just before I do, however, do you plan to update the theme anytime soon? If yes, that I would prefer to wait.
I can tell you exactly when it will be an update, but it will be soon as possible we hope at the end of the next week.
