i am Facing issue with catogry display
Hi team,
I have used article display view 1 for my blog. I have found some gaps in between the post please refer the image so that you can get an idea
https://plus.google.com/photos/photo/100119026409991123727/6428513717216938562
Hello ahmedyakub,
These gaps appear because you do not use the right post limit number. You should set this limit to be divisible by 3 to fit all the spaces, from here -> https://www.screencast.com/t/lqePwNVVp
Hope this helps!
thanks for the reply I will check it.
For the below http://blog.yuppflix.com/movies/hindi-movies/ I don’t need title and description display on page can you please help me
Hello ahmedyakub,
Here is talking about Category description and page title. If you want to remove it, you do not add the description from each category, in the panel, like this -> https://www.screencast.com/t/vQOk4r8V and also, for the page title, you can use a bit of CSS code. Or also, notice that you can change the page template to another one from panel, like this -> https://www.screencast.com/t/rfzBQ02T
.td-page-title{
display:none;
Hope this helps!
