I am having home page problem
Hello there, Kindly check the screenshot and help me with this situation. I dont know how to fix it
https://prnt.sc/E10on4MpTLk-
Did you use Elementor plugin before or you did some changes to the page with it?
If yes, you can try to use a revision of the page.
I am using elementor but I didnt change any pages. How can I contact the support team
Here is the team support. If you made changes with Elementor, then this is in conflict with tagDiv Composer, our page builder.
Please try to recreate the page using the tagdiv Composer.
Also, if you added in the post blocks from Elementor, please delete them and check after.
can you please login and help me out. I am not that much good with these kind of technical issues. It would help me out really. Just tell me where should I submit the login details.
We can take a look so, please contact us via email at contact@tagdiv.com and provide the wp-admin and cPanel login
I am facing this problem
https://prnt.sc/_8kIV64QZROc
I have mailed but didnt receive any response
You can edit the homepage with the TagDiv Composer, click on the hamburger menu and choose the menu you need from select menu. You can build the menu from Dashboard -> Appearance -> Menus.
