I am having problem Some Problem With This template!
First: My Site Mega Menu is not working can you please tell me how to get out of this?
This is the URL Of my site: http://www.stuffzombie.com/
Second Thing: Can You Please Explain me that how can i make my big slider Moveable?
Big is slider is not moving right now you can check by visiting the same Url I mentioned above!
Waiting For Your Reply Thank you!
Regards: Faheem Hafeez
The mega menu isn’t working because you don’t have any posts in the categories you have set to use mega menu.
In this category you have posts: http://screencast.com/t/feQyNhO2ShE and in this one you don’t: http://screencast.com/t/qcQIQA31
For the slider to slide it needs to have more than 4 posts as 1 slide uses 4 posts then if 5/6/7 posts were added then your slider will start to slide so make sure the slider has more that 4 posts to display and also make sure that this options are set to show more than 4 posts: http://screencast.com/t/g2QVw8cdFiCJ
You should also consider going trough this mega menu guide: https://forum.tagdiv.com/how-to-use-the-megamenu/
