I am not able to add nofollow and dofollow links in pages or posts or texts.
Hi, recently I created a site ‘https://www.themefollow.com/’ with a Newspaper theme but when I am going to post and want to add a link then I am not able to add nofollow and dofollow links in pages or posts or texts.
After lot’s of plugin’s check I found a plugin ‘WP External Links’ but it’s added all links dofollow or nofollow and it’s not possible to convert any nofollow to dofollow link. I need an option for every time so that I can select every time that it will be dofollow or nofollow. I have not coding knowledge so please give me a easy solution or a plugin. Please help me. Thanks.
Unfortunately our theme do not have this option, sorry! Also we we do not tested any kind of these plugins, therefore we do not know each one to recommend. The only solution that we can provide is the code that you need to set for the links to be nofollow or dofollow.
If you want you can check other plugins for this, maybe you’ll find one that is working on individual links:
5 Nofollow WordPress Plugins 2020 (Free and Paid)
5 Best Nofollow Link Plugins for WordPress
Free 7 Best NoFollow Link Plugins For WordPress
