I click on a title, shows the article when I scroll down is showing more posts
Hello, I have the following problem, when I click on a title it opens the article and as I scroll down it keeps loading more articles, I only want it to show 1 article not all the other that are loading up. I just want to click on the title, see the entire article and when I scroll down get to the footer only, not endless articles loading up. Can anyone help with this?
here is one of the articles with endless articles showing up:
http://onlymiriam.com/you-need-lemon
thanks in advance
That option is possible when using Cloud Library post templates: https://www.youtube.com/watch?v=I1R3j1QYod0
You can activate or deactivate the infintie scroll from here: https://tagdiv.com/infinite-loading-for-single-posts/
Regards
