I have a problem with the mobile theme.
Error: The mobile theme path couldn’t be set. Please check if you already have another mobile theme plugin active and disable it (ex. Jetpack Mobile Theme or similar). If you use a cache plugin clear it before checking the results.
URL: http://es.ufosonearth.com/
Hello ufosonearth,
Please ensure that you are using the latest version of the theme (Newspaper 7.2 with Visual Composer 4.12 and Social Counter 4.1) and try to use it without any untested plugins which might interact with the theme and create a lot of unknown issues.
I have the latest versions that you mention.
Could you give me your experience based on a list of plugins that could cause this failure?
Hello ufosonearth,
This type of error might be generated by any plugins which are not included in this list -> http://screencast.com/t/C4ZnWEddM5 If you are using these, please try to deactivate all of them and rule out the conflicting plugins.
Hope this helps!
