My site is frelsitv.com
I have a bug or an error on my post page . . . please help me solve this problem https://www.dropbox.com/s/zqpx2yjfv16hsu9/2905.png?dl=0 . . .
This is my 3rd time asking for help on this issue ๐
LIKELY YOU NEED TO BE MORE SPECIFIC ABOUT THE PROBLEM !!!!!!!!!!!!!
Is it the social plugin you’re using ? What’s the issue ?
Is it the lack of images for the related posts ? Did you assign featured images to all those stories to generate the thumbnails ???? Are your feautured images large enough to be as big or larger than those thumbnails ????
Probably if you’re more specific of WHAT the problem is somebody could actually try to help, you might get some help from the community more quickly ????
NOTE: you have some errors related to Facebook which appear in Chrome when using the debug tool (F12 key) …
Given URL is not allowed by the Application configuration: One or more of the given URLs is not allowed by the App's settings. It must match the Website URL or Canvas URL, or the domain must be a subdomain of one of the App's domains.
Looks like it might be the Facebook comments plugin you’re using is not setup properly. Theme devs can’t help you manage other folks plugins — you need to sort that out on your own first, when possible. Did you ask them for help ?
<!-- Facebook Comments Plugin for WordPress: http://peadig.com/wordpress-plugins/facebook-comments/ -->
Did you try turning off plugins to see which one might be conflicting with other theme elements?
TagDiv support also closed weekends (as noted top of every page here).
But they should be back in the saddle today/tomorrow.
Sorry if that is no help. I don’t work here, but try to lend a hand when I have free brain cells. !!!!
simchris.
I don’t work here … so you will likely get loooooong silences from me ๐
I just pop in to give advice sometimes since I’ve been suffering WordPress for 9 years now, and doing webdev for 20 years; and using TagDiv themes since Fall 2013.
Glad you got that sorted!
