i have problem about site view in multiple platform:
my site: http://www.electro-marine.net/
site It should have this appearance: https://imgur.com/a/IwvOefw
Watch through Mobile: https://imgur.com/1Au7Shq
Watch through Desktop: https://imgur.com/hvcyNWs
Please help
I’ve checked your site, but I cannot see the reported issue.
Desktop – https://www.screencast.com/t/99gQGOLNr
Mobile – https://www.screencast.com/t/nHdUcXy1StGN
That seems to be an unusual design for the team member element
– https://www.screencast.com/t/3S8K8pWE
You could have used the row split in 4 columns to achieve a similar result, easier also
– https://www.screencast.com/t/oWBinmCrjcnT
Basically what is causing that is the width I believe you set here
– https://www.screencast.com/t/Ams7x87eUigg
The result of that is that the team member element will occupy 22% of the available space on desktop and mobile.
Without the width on desktop – https://www.screencast.com/t/anoJQddAhAr
On mobile – https://www.screencast.com/t/24qmoNORYZH
Maybe you can redesign the layout, to avoid this result.
