Hi, i have problem and something in theme make problem and use resource . http://www.kucnilekar.com
Ihave 2 website and the same theme and i never have a problem.
Can u help me i give u access!
Regards
Zdenko
In our case, usually issue with “too many” modules on home page, randomized elements, queries to external sites (socials), infinite loads, etc. Main thing is try to plan on limiting number of “modules” used on sidebars and home page. 2-3 sidebar modules max on posts; and maybe 4-5 max on home page.
(I don’t work here.)
There are indeed features from the theme that consume CPU; it depends on what’s used on the page. If it’s not a matter of high traffic, incorrect caching/optimization, or malware, then something else is causing it.
– https://forum.tagdiv.com/topic/theme-causing-high-cpu-usage-2/
– https://forum.tagdiv.com/topic/sql-querys-high-cpu/
