I have problem with post cover picture.
Hi there,
I have problem about page load all time the picture cover not show up and sometime the picture showed and just disappear when page load finish.
you can see this screenshot https://www.img.in.th/image/RqK will see what my problem. Do I need to set up or customize theme ? Is this hosting problem ?
Thank you
I have checked your site and did not found any issues – http://screencast.com/t/YTPN4V78AY If you want to remove the lazy load effect you can disable it from Theme Panel > Template Settings – http://screencast.com/t/h9HqPnnVK maybe when you have active a plugin cause an issue.
