I have problems with facebook embed
This problem started since the new update:
aa
Hello geolz,
Try to re-create and embed again your Facebook where you want. Also, you can provide your FB code so I try to add it on my website so I can check the results with it. If you are using some untested plugins, you should remove all of the untested plugins, leave just only of our required plugins to be active, clear all the caches and check the results.
