I have problems with my footer
I have downloaded the template “Footer – Pulses PRO” and have edited it on the homepage. But when viewing the footer on the article pages, the footer is completely deconfigured, showing what I show in the images.
Footer on homepage:https://imgur.com/yn1jq9f
Footer on article pages:https://imgur.com/vnRVAgy
I have blurred the text just for privacy.
Hello @lavr0003!
I’ve tested and imported the footer and everything comes in place.
Please re-import the footer and see the results.
If the problem is still there, then the issue can be from a plugin conflict or a cache issue, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache (also from your browser) and try again.
Hope that helps you!
