@in2town Sorry to hear about the problems you are having. The theme and the mobile theme will be improved. But this may take some time, for the implementation and testing, other projects being developed at the same time etc. Hopefully it won’t be long now from what I know, and the modifications will have a positive impact.
+1 to fix those mobile friendly and speed issues firstly, instead of adding new features which are not really necessary
any update on this? I still have these issues.
vamsinani24.
@vamsinani24 I see you use the mobile theme, with it active the website should be mobile friendly. I checked a few posts, looks alright – http://prntscr.com/o0sm5v
AMP looks alright as well – http://prntscr.com/o0sn4s
What are the problems you are facing?
@simon I disabled cdn on mobile and also disabled caching and that’s why it’s working. The moment I enabled any one of them, I get both errors that’s mentioned here. Would like to know if there’s a way I can still serve images over the cdn.
I use keycdn and wp rocket for caching.
Maybe the cache is causing the mobile theme to not work or apply properly. There are cases when the mobile theme doesn’t work for some pages, applies on desktop, etc. With the super cache plugin the mobile will work properly, but with other caching plugins or services there could be problems unfortunately.
@simon, even I thought the same. The mobile cache might be causing it, but as mentioned, I’ve disabled it, and it turns out, even the CDN is causing the issue. I also tried wp-super-cache, but the problem with the mobile version still exists.
