I have upgrade and I checked the pagespeed, there is problem.
Hello~
I have upgrade from ver 9.0 to ver. 10.4
And I tested pagespeed.
There is error message like below
Lighthouse returned error: ERRORED_DOCUMENT_REQUEST. Lighthouse에서 사용자가 요청한 페이지를 안정적으로 로드하지 못했습니다. 올바른 URL로 테스트하고 있으며 서버가 모든 요청에 적절하게 응답하고 있는지 확인하세요. (상태 코드: 403)닫기
What should I do?
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
To remove CLS please check these guide: https://developers.google.com/web/tools/lighthouse/ ; https://www.sqlpac.com/en/documents/google-pagespeeds-lighthouse-6-new-features-lcp-cls.html ;
https://web.dev/lighthouse-whats-new-6.0/
Hello~
Thank you for your quick response.
1. I did what you suggest,
“please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.”
2. I didn’t understand the last thing, so I did nothing about that.
‘To remove CLS please check these guide’
3. I operated the pagespeed.
ongajok.com
4. pagespeed error message continue.
‘Lighthouse returned error: ERRORED_DOCUMENT_REQUEST. Lighthouse에서 사용자가 요청한 페이지를 안정적으로 로드하지 못했습니다. 올바른 URL로 테스트하고 있으며 서버가 모든 요청에 적절하게 응답하고 있는지 확인하세요. (상태 코드: 403)닫기’
5. I have a question
Does that mean I already install CLS?
What should I do for to remove CLS?
  • This reply was modified 5 years by lowhoh.
Please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate more into this issue and see what can be done in your case. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
