I hawe a publishing post problem
when i try to create new post or page i get erorr “publish unsuccessfully”
Do you use the latest theme and wordpress version? Does it happen in Gutenberg? Also does it happen if you deactivate all plugins except theme plugins, or test with a default wordpress theme?
There are some similar topics you could check out, mentioned by users after the wordpress update, seem to be quite a few possible causes. For example
https://wordpress.org/support/topic/publishing-fail-after-update-to-wordpress-5-0/
