I NEED AN URGENT HELP PLEASE
I have finished creating the website but it is not showing on mobile. I want to see exactly the mobile version of my desktop version. This is my site https://insideeko.com/ Further more my site loading is terrible slow as the lock at the https:// area shows warning sign and this happens only with your theme. I tried a different theme and the locks shows green content loaded fast. Please can be causing the extremely delay load?
** Please can you help me remove the last section of the site before the footer. it is titled LATEST ARTICLES. It is showing differently from every other part of the site I arranged and I have tried to remove but couldn’t find a means.
*** Please the Rating Star only show yellow colour when I open a post, but on Home, they show black stars. Please I will like the Rating Stars to show yellow on Home.
Seems that there is still a demo image set somewhere in the theme panel, that was not changed. This image causes a mixed content warning – http://prntscr.com/nyqslz
Try looking for it here – http://prntscr.com/nyqsyt remove it or change it with one of your images.
I checked the website on mobile, looks fine. That is how the mobile theme looks. If you don’t want the mobile theme, you can deactivate it as it is an optional plugin. Then the same content from desktop will appear on mobile.
The latest articles section will appear at the bottom of the page, if the required template is selected for the respective page – https://forum.tagdiv.com/page-templates-2/
To remove it select a different template, like the default page template for example.
I believe you are using the code for changing the review star color from here
– https://forum.tagdiv.com/topic/i-cant-make-use-of-your-theme-yet/
I made it so that it applies only in posts, but I can modify it to apply everywhere.
– http://prntscr.com/nyqy5h here it is – https://pastebin.com/bUBrVBKB
Remove the previous code and enter this one.
If you have more questions let me know.
1. Please I don’t like the way quotation appears on my site. A clear example is https://insideeko.com/federal-high-court-orders-amcon-to-take-over-victory-park-estate/ can you please help me change the way that quote shows.
2. I cannot see all my post on my Mobile view, what can I do?
3. I changed the rating star colour from Black to Orange and it is working only on desktop view, how do I make them work on Desktop and on Mobile?
1. You can change the quotation from Theme panel>Theme Fonts > Post content -> https://www.screencast.com/t/LJs79t0Yu also you can change the color too -> https://www.screencast.com/t/9WWM0dq1vwzJ
2. That is happen because you are using the mobile theme plugin, if you want to have the seam content on mobile as on desktop then you need to deactivate the mobile theme plugin.
Please check this similar topic -> https://forum.tagdiv.com/topic/mobile-help-homepage-different/
3. Dis is also related to the mobile theme plugin.
PLEASE HOW DO I CHANGE THE (LOAD MORE) COLOUR SO IT CAN BE OBVIOUS TO READER.
Hi @arivibez,
Please check this topic for load more button -> https://forum.tagdiv.com/topic/mobile-help-homepage-different/?view=all#post-304183
