I need help to adjust the Row gap on how to adjust the Row gap, I want to use a small gap between two Row. this default gap is too large for me, I was using the collum gap adjust but I can’t find the ROw gap.
You can change the gap between the elements using tagDiv Composer -> https://www.screencast.com/t/b5rLIcMBxZK in order to remove the gap, set the margins with “-“, instead of 50 set -50 this will reduce the space, also you can set the margins to 0.
Hope this will help you!
The gap from header can be reduce using tagDiv Composer only if you are using a cloud header, if is a standard header then you can adjust it with custom css.
If you want I can help you with this, just provide a link to your website and I will guide you!
