I need help with sidebar
Good Afternoon,
I need more help, i wan’t two more information :
– I don’t wan’t latest article in my home page
– I wan’t the sidebar go up to the homepage
Best Regards,
Noé
Hello BeeSens,
I suppose that you are using the pagebuilder+latest articles+pagination as a page template for your homepage, right? So, if you want to get rid of it this, please notice that you will have to switch to another page template. For more information about this, please check here -> https://forum.tagdiv.com/page-templates-2/
For your second request, if you do not want to have the sidebar, you will have to use the 1 column when you edit your homepage, like this -> http://screencast.com/t/2tcmf5tKcL For more information about how you can use Visual Composer, please check here -> https://forum.tagdiv.com/how-to-use-visual-composer/ and also, for more references about sidebars, please check here -> https://forum.tagdiv.com/smart-sidebar-2/
If you refer to something else, please provide more details.
Thaks for your understanding!
Good Afternoon,
Prefect so i can create my own sidebar ? And i found where can i delete the latest article.
So i need one more information i wan’t to add mailpoet subscription in my sidebar but i don’t have any shortcode in MailPoet Settings so what is the code for last one ?
Then anotthe information look the two arrow in my screenshoot : http://www.noelshack.com/2016-26-1467040425-capture.png i don’t wan’t any more space here.
Best REgards,
Noé
Hello BeeSens,
For your first request, I suppose that you are using a plugin for this feature right? Please notice that our theme has not been tested with this type of plugin, we have no idea about the theme behaviour with this and we cannot provide support for untested plugins, sorry!
For your second request, please notice that this is the default space of the theme and if you want to reduce it you will have to increase the width of the theme and we do not recommend doing this because you can damage the theme and we cannot provide customization services at the moment, sorry! If you want to do this and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you.
If you need to have a full-width grid or slider for your side, you can try to use the Revolution Slider, according to this documentation here -> https://www.themepunch.com/revslider-doc/slider-revolution-documentation/
Good Afternoon,
So if i wan’t to reduce the space beetween the two arrow it’s not simply and not very good for the theme ?
Best Regards
Noé
Hello BeeSens,
Yes, please notice that is not an easy way to achieve this and if you do not have a solid experience in this regard you can break the layout of the theme. If you are not aware of these steps, please consider hiring a freelancer/developer to help you.
