I noticed a few problems for mobile.
Before thanks for this theme and working. i love it..
1 – Post inline:
td
2 – Contact page not working (Contact Form 7): http://kuaza.com/iletisim
3 – How change mobile home page. Example, how add grid on top new article?
4 – How add adsense attachment page ?
Thank you for your appreciation.
1) Please install visual composer as the plugin is required dor the theme elements to work properly: http://screencast.com/t/NvYhYEWfc
2) The form seems to be working properly from my end. Please check it again. http://screencast.com/t/KYTifjaH
3) If you use the mobile theme, then things are a bit different here as the mobile theme does not use visual composer in order to get good loading speeds. You cannot esit the homepage as it’s predefined to show only a big grid with featured posts filtered (yopu need to add them to the ‘featured’ category ) and a latest articles element. All your pages that have been created using visual composer will have to be re-created for the mobile version using the secondary mce editor you can see in the back-end. basicaly you will have 2 versions of your pages.
4) You can add google ads in our theme through the theme panel: http://screencast.com/t/vnCFbKnvY
You can read more about ads here: https://forum.tagdiv.com/header-ads-adsense/ – http://screencast.com/t/zGPK6QyR
Thanks for reply.
visual composer is active, but for post not working visual composer.
And what: td_block_big_grid_mob_1 (front-page.php)
not working this area, and im added new list.
and for mobile theme is working wp super cache ?
  • This reply was modified 10 years by kuaza.
We do not recommend using visual composer on posts as this is not tested and could provide mixed results. It can be activated from here if you want to use it anyway: http://screencast.com/t/x89t2ehtvV
Thanks for all reply. Good job, good working 🙂
