Hi, I am trying to create a text block or raw html on VC with the background transparent like the categories style 6 template https://forum.tagdiv.com/wp-content/uploads/2015/05/2015-06-15_16-44-07.png but i am failing (my css skills are almost zero), I will pay 15$ by paypal if someone can create the page and export it.
Some css expert is able to do that?
Cheers!!
Is not possible in page at middle to give a transparent background, because the container have a white background color, there need to make some grid css changes and customize only for what you have only on that page.
Do you mean to use a background image on you page like this: http://screencast.com/t/MdZmhIiEkoX
If you don’t use a background image on your site and want only a background image on a specified section this can be achieve with the visual composer without no modification of code, like here:
http://screencast.com/t/rBY9rAtXR
http://screencast.com/t/o1nzdY7oOnwc
Yes, its that that i seek, I loved this effect and want to use it on a text block on the home. If is not possible replicate the categories effect then i am thinking in create a “fake” categorie with the only propose of use for that, maybe can work…
Thanks for the help!!
