I really need help with my sub categories plz don't ignored me.
1. https://imgur.com/Ecroxn7 can I have more than one menu that has subcategories like this one? https://imgur.com/eq81rCY
2. I don’t know why it’s not working even tho I did change my setting. and seems like the limit is 4. https://imgur.com/nLgeWAV , I did do some testing, I can literally change to 1 , 2 ,3 ,4 and these work perfectly fine. but I don’t know why it didn’t work if is exceeding 4
I’m goin insane.
  • This topic was modified 6 years by Rex.
Hi Rex,
Nobody ignoring you, but please notice that our support is not instant.
This is a mega menu with-out subcategories -> https://i.imgur.com/Ecroxn7.jpeg and this one is with subcategories ->https://imgur.com/eq81rCY now in order that this option to apply -> https://i.imgur.com/nLgeWAV.jpeg you need to make sure that you have more then sub-menus for that category, for example I have only one subcategory for this category -> https://i.imgur.com/LWMYJcX.png if you have those set and the problem persists, please make sure that you do not have any plugin conflict, disable all non theme plugins and let only tagDiv plugins.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login. We will take a look. Include a link to this topic in the email.
