i Want to put ad after 1st and 5th paragraph inside the post,
But in current ad settings inside my dashboard i can’t do that..i can only place one adsense ad inside the post(After the paragraph).
Please give me guide on this problem.
Alternatively you have a ads plugins with wide option to set on my site, or very best suitable for my newspaper theme. if possible i don’t want to use ad plugins. But if you suggest than i can do.
Thanks and reply As soon as possible,
Unfortunately theme doesn’t have an option for this. You can set only one inline ad to appear after x paragraph: http://screencast.com/t/KIvZopLJQqPH
I can’t suggest any plugin for this as we didn’t test it with the theme, but you ca try. Sorry!
