I want to reduce space between to rows>column (element) ??
1. I want to add a verified badge next to the author’s name in comment replies not any other Style.
2. Your code is hiding the whole date and time. I want to hide only time not date.
1. This can be done with custom work.
2. Unfortunately, you can not hide only the time.
Everything was going fine so far. Then I opened one page, went into “Edit with Composer,” and added an ad code under the header — and later removed it. I think I accidentally deleted something else too, because ever since then, extra ads are showing in the header and footer on the pages, category, and author pages — ads for which I haven’t placed any ad code anywhere.
Also, these are not showing because of AdSense Auto Ads. They’re only appearing due to some changes I made in the design of that page.
Check live pages:
https://techunpaid.com/privacy-policy/
https://techunpaid.com/category/instagram/
The 2 ads showing above and below (in the header and footer) — I haven’t placed them, nor are they from Auto Ads. There’s something wrong in the theme settings somewhere.
And what page template should I select here in Cloud Template:
https://share.zight.com/wbudq0kb
Only these options are showing in my theme:
https://share.zight.com/7KulN0R7
And if a wrong option is selected by mistake, how can I rollback or recover it?
I want to restore the pages section back to how it was earlier so that these 2 extra ads don’t show up.
These options are currently appearing when editing any page in Composer:
https://share.zight.com/BluePZ1L
Help me to remove the extra header and footer ads. I want it to be like it was before.
I just checked the mentioned ads and those are auto ads – https://i.imgur.com/vdb1rG9.png – https://i.imgur.com/mrSrDkX.png so if you do not want auto ads on your website you can disable them from your AdSense account, or restrict the zone you want them be to displayed https://support.google.com/adsense/answer/12626543?hl=en
Viewing 4 posts - 51 through 54 (of 54 total)
