IE10, IE9 will not work properly.
There seems to be a compatibility issue.
How do I fix it?
site address : http://www.mediamo.co.kr
Please test our official theme demo at https://demo.tagdiv.com/newspaper/ on ie 9 and 10 to see the theme in it’s default state.
