Right now I have 3 glaring issues with the theme —
1) Over 3000 instances of CLS errors (caused by adding an advertisement image in Theme Panel > Ads > Header Ad). This is really hurting my SEO.
2) The modal image / popup images doesn’t work site-wide (unless you change it on each one individually on every post). This has been acknowledged as a known bug in Newspaper.
3) Customize the default spacing / padding on the site
1. For cls, please try to use the element ad box, and set the images in the element.
2. For the modal image, we added a fix in version 12.4, it doesn’t work for you please contact us via email at contact@tagdiv.com, please check if you don’t have a plugin conflict, also.
3. Please let me know what you want to customize, you can do it with tagDiv Composer.
