I recently purchased and installed your theme, but I’m seeing these errors at the top of my website:
Warning: Illegal string offset ‘td-multipurpose’ in /homepages/4/d675298448/htdocs/bfw/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 646
Warning: Illegal string offset ‘td-multipurpose’ in /homepages/4/d675298448/htdocs/bfw/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 1230
Do you know where I might have gone wrong?
Many thanks,
Ben
Hi BenFranksWine,
Where is aspiring these warnings? are in pages or posts?
If is on pages then is possible to be a problem from our theme, we reported this to our developers to check what can be the problem and provide a fix as soon as possible, therefore it will be soon a theme update that should fix these kind of warnings.
Hi Calin,
It’s occurring on any empty content pages by the looks of things. Look forward to the fix.
Best,
Ben
Hi BenFranksWine,
Our developers made a fix for the above problem, this will be add in the coming updates. If you need it now, then you need to make the follow changes in theme files.
wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php then under line 645 you need to ad a code -> https://i.imgur.com/A3Sq7zk.png -> https://i.imgur.com/7Zl9pCS.png
if(empty($extra_icon_fonts)){
$extra_icon_fonts = array();
Then you need to go for the second Warning that was before on line 1230, now this will be on line 1232-1233 -> https://i.imgur.com/4jvz4kR.png there add again the above code like this -> https://i.imgur.com/1bSATjC.png
This should fix the problem!
Hope this will help!
