Warning: Illegal string offset ‘test_time’ in /home/unisa602/public_html/wp-content/themes/Newspaper/includes/wp_booster/td_remote_http.php on line 93
Warning: Illegal string offset ‘test_status’ in /home/unisa602/public_html/wp-content/themes/Newspaper/includes/wp_booster/td_remote_http.php on line 95
Hello rodrigocouto,
Ensure that you are using the latest theme version which comes bundled with the theme core files. Check your system status parameters to be increased according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ If you are using some untested plugins, try to disable all of these and leave just only the plugins that come bundled with the theme core files and rule out any conflicting plugins. Also, if the problem is still there, you should make a new clean install from scratch via FTP way and install only the bundled plugin to rule out any conflicting plugins. If you are using a CDN system, you should purge all of the CDN files, clear all the caches and check the results.
Hope this helps!
