IMAGE BOX – Problem with subtitles
An image box error is occurring. I created a line, with 4 images side by side, all with caption, but the caption only appears in the last image. Link to inspect:
http://www.clickcamboriu.com.br/clicks
The caption is not showing . Only titles show but on your end only the last one has a title because you did not set any for the others. You have to set a title for each image in particular. You only seem to have added a title for the last image. Please provide a screenshot of how you set it up in the back-end
Bogdan B.,
That’s where the problem is. I set a title for each image !!!!!
screenshot
The title are not coming up at all in the html code. Please disable all plugins except visual composer, clear cache and reset cdn files. Then test the images again.
If you still have the issue, please contact us via email at contact@tagdiv.com and provide a link to this topic and wop-admin so we can login and investigate.
