Image size problem with single images in mulitple columns using vc
Hi there… I’m using the new NewsMag 4.1 still with VC.
Now single images in Columns are not working correct anymore.
See:
https://www.recyclingmagazin.de/mediadaten/
The four images should be side by side each but scaled to be fully visible.
This was the case in 3.3 but now they are displayed in full with. Also the
links are not working anymore that have been bound to the images.
Please advise.
Cheers,
Guenter
Update: it seems to be related to incompatibility from vc and tc. As soon as tc is active, the images don’t look right. I don’t want to switch to tc at the moment. Will vc be supported in the future? Is there a way to fix this issue while having both composers running as I won’t be using two on the same page but will need time to get used to the new one and don’t want to convert all pages at once.
Hello hagedorn2,
It’s not recommended to use both page builder simultaneously. For more information about transition between these two builders, please check here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
