Hello Baraka,
First of all, please ensure that you are using the latest theme version and also if you are using some untested plugins you should remove all of them and leave just only the plugins that come bundled with the theme and rule out any conflicting plugins. It seems to be issues regarding on JS which apply the opacity:0 for all of your images and the value of it should have to be 1. If the problem is still there, you should provide your website URL after you made the above-recommended steps.
I follow all recomended steps but i still getting same problem
Hello Baraka,
I have inspected your website and I saw that your images are right displayed, as you can see here -> https://www.screencast.com/t/8CncYHadba Try to clear all the caches and check the results.
