both in the desktop and in the mobile device view, the images that I have inserted into the posts with Media Grid are not loaded.
Why is that?
2. Question: Why is wpbakery not updated with the newspaper update?
Thank you
https://makanangin.de/waterberg-wilderness-das-andere-namibia/
You can see from the changing gray dots that images should be loaded there.
If you had an old version to your plugins, then the theme update is not updating your plugins automatically. Please try to re-upload the images and see the results.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
