You don’t get all the images from the “demos” — as they are licensed images. Meaning you don’t get 100 free stock photos with theme; you get the demo “layouts” and CSS, and need to use your own images. The demo is to help you setup a look/feel for your site, not give you a ton of free content and photos.
So, this is normal practice with themes bought from ThemeForest — as the demo images were licensed to TagDiv and not to you.
If that was not the query you meant, and I mis-understood, please pardon my input. I don’t work here but have been using TagDiv themes for 2 years now, and run into various such things in my own travels. 🙂
Hi Chris,
Thanks for the response.
The thing is, all the images are loaded in the library.
In fact, I can see all the images in the ‘Edit Post’ section of my wordpress dashboard.
Even when I add my own images in my own posts, I do not see them showing up.
OH …
you can turn off the “lazy loading” images feature – which seems to impact some people but not others, and some browsers but not others … that may be why you see an image in the edit, but not live on the page when posted!
Find that setting in the theme admin panel and turn OFF.
Well… it works for some folks and not for others — no idea why. I ran into this same issue using mod_pagespeed (which has built-in lazy load function option) on our site 15 months ago, and chose not to use it for same reason. I’d see randomly no images loaded. Meaning, the top of page items might load, but if somebody waited then scrolled down, there would be no images at all … super annoying.
The trade off with lazy loading is that some browsers and some setups just don’t exactly work consistently since it’s kind of an ajax load on demand thing — much like some of those long parallax one page website sometimes just crash the web browser which is super annoying (most folks have given up on that, thankfully).
I’ve disabled it on all our sites for this same “inconsistent” issue.
TagDiv support might have better answer … but that’s been my WTF? experience 🙂
simchris.
