Images do not load in infinite scrolling mode
For a few days now, when scrolling infinitely on the website, the images do not load. The broken link icons appear: https://www.lacasadeel.net/
https://imgur.com/a/V3YoLqj
  • This topic was modified 4 years by Beldar.
Hello @Beldar!
I’ve checked your website and it seems that they are loading, but slowly, till the page is fully loaded. I recommend you to optimize your images and your website page speed.
Hi, I’m sorry, but you didn’t take a good look at the fault I’m talking about… In the Home page, if you scroll down, the infinite scroll is activated, and all the news that load in it appear with the image with error (see the screenshot).
As for the speed of the website, we have followed your recommendations: Improved CSS, WP Super Cache, Cloudflare Pro and we tried Autoptimize, but the latter gives error.
https://imgur.com/a/eomhgaR
Hello @beldar!
Yes, sorry for the misunderstanding. I’ve tested this feature on my end and it works well.
Please make sure you have the latest update of the theme and plugins, also make a test, deactivate all the cache plugins and the extra non-tagdiv ones, clear the cache from your browser and see the results.
Hope that helps you!
Hi, yes, I have both the theme and plugins updated. I have tried deactivating all the plugins on my website, deactivating the caching systems and I have connected from the browser in incognito: the images are still giving errors.
I have found the problem: images do not load in Infinite Loading when they are in normal Blocks, but they do load when they are Flex Blocks. Why does this happen?
Hello @beldar!
If you use default templates or old blocks, then please make sure you have Standard pack plugin installed and active.
Let me know the results!
Hi. Yes, I have it installed and activated all the time, so that’s not the problem.
Hello @beldar!
We can take a look for this and investigate why is not working for you. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Our team will take a look!
