Some images do not display correctly. I already checked thumbnails, compressed images, did everything I could. I have a cache optimization plugin.
I also did the test by disabling the cache plugin, but still the problem persists.
It occurs in the posts, some images and the home page.
I already cleared the browser cache. Can you help me?
https://prnt.sc/kn2o5b
