Hello Newspaper developer,
I would like to suggest to make an update which makes the blocks compatible for Firefox and Microsoft Edge. Only in Chrome my website appear in the way that the theme is designed.
Thanks in advantage.
My website: http://www.paarsevlinder.nl
Our theme is compatible with all major browsers as it can be seen on the envato page in the right side: https://www.screencast.com/t/UY8iFvv97
You have errors on your site and that is why it does not display the way it should.
Please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Thank you very much. It is solved. Plugin Cookie Bar and
RS Head Cleaner Lite was the conflict.
