Images go in long line instead of side by side
I do screencaps for shows and post them on my site and when I do the HTML for them they all go in a long row down the page instead of being next to each other. It worked on my previous theme and I was wondering if I am missing something with this theme that I need to do.
You will need to provide more details if we’re to help in this matter. Please provide a link to your website and an example on how you are implementing these screencaps so we can investigate.
Here is a page that I shows the issue:
http://crazymax.org/newsite/caps/rumble90caps/
Here is what they should look like:
http://crazymax.org/newsite/caps/snme8caps/
Your 2 posts you have provided have different implementation. The one that stretches in the long row does not get the align-left class as the images on the second post. Please check your html code to see if there is anything different in the post that does not display properly. Maybe you should consider adding them inside a list or using floats to position them properly as the post that “works” does not display the images properly as well. You can find good html and css tutorials here: http://www.w3schools.com/
