Hello TagDiv,
For some reason, all my images have become low-res across Desktop and Mobile?
I am using WP Retina and Jetpack’s Photon is also active. This never used to happen before and now all of a sudden, I have very low res images.
Do you know what could be causing this?
Website: http://www.glitched.co.uk
Thanks,
please disable all plugins excepot visual composer, clear cache and reset cdn files if you use it. Then check the images again. If they are not back to their proper resolution, you may have to regenerate the thumbs: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
Image optimization tools usually create this issue but other plugins can cause it as well.
Let us know how it goes.
