Images in blocks not aligning
Hi there!
Have a local problem, only happened on one of the computers. Normally in chrome, but now it also happened in Firefox. I can’t for the life of me find out why this is happening, som maybe you can help?
As you can see from the attached image, the blocks won’t load like they should.
This happens in firefox and chrome (not IE, but I hardly ever use it). Previously it did not happen in FF, wich is my prefered browser, so I did’nt care much about it happening in chrome since it seemed to only be the case on one computer. I have previously fixed it in chrome by resetting it completly (clearing history, cache++ does not work).
As you can see, the white-space (the image that should occupy it is now beneath it, not beside it)
Image alignment problem
But now it’s also the case in Firefox. And if this happens to one of our readers, it would be nice to know what’s causing this. In case you’ve stumbled upon this before.
It only affects our website, not others with the newsmag-theme.
  • This topic was modified 11 years by vdaatland.
Please check if the browser zoom it’s set to default value, because otherwise appear some issues with the layout http://screencast.com/t/o7zGWqA4aVW This is valid for all browsers. You can set the zoom at default value using CTRL+0 command.
Let me know how it goes.
Hi!
Well what do you know. A simple solution, works perfectly. It happens when one zooms to much, just as you said. Thank you very much!
As always, the customer-support is awesome.
