Images inserted inside a post are too small. Check here https://prnt.sc/savcfa
How can I make then appear in original size or just like the featured image?
All posts. Here is one of them: Too small. But when I put the same image as a featured image it shows well https://jabulanews.com/list-of-best-hotels-in-kakamega-county/
What you can do is to change the image size that is display in flex block on homepage, edit it with tagDiv Composer -> https://i.imgur.com/1Vm9rh3.png -> https://i.imgur.com/len5XqK.png -> https://i.imgur.com/eSNOsy5.jpg
Hope this will help you!
Please note that they are images attached inside a single post not element images. Look at this post https://jabulanews.com/list-of-best-hotels-in-kakamega-county/
You will not that image attached inside the post appears to be too small. How can I solve that and make them much bigger
The image inside the article can be edited only from inside the article, when you load an image you can select the size -> https://i.imgur.com/Bgs7F5c.jpg also you can resize it like this -> https://i.imgur.com/qCQfPPQ.png suing Gutenberg editor -> https://i.imgur.com/Ot3SOmG.png also in some cases there can be some plugins that affect the size o image.
