Images inside text block and Single Image blocks problem
Images, despite being 2000px width are not displaying full width inside a text block.
Single image block, set at size full, is not following the height of the image.
Problems happened after the latest update.
Last, the tagdiv composer gets stuck on loading.
Kindly advise.
I am having same problem after theme update to 8. The single image block in visual composer is not displaying correctly and the links don’t work when using it as well.
A work around that other people suggested is disabling TagDiv Composer. Then images will display properly that use the Single image block. The only problem is that post created/updated when plugin was active will not display any content.
Please do not use both page builders at the same time. Choose one or the other. We recommend switching to the tagdiv composer as we will develop our theme in the future based on our own page builder, not visual composer. You will still be able to use visual composer in the future but it will remain with the options available for it now. We will not add any new elements to visual composer. We will add lots of new and cool stuff to the tagdiv composer though.
As for the loading screen on the page builder, please increase your memory allocation by following this guide: https://forum.tagdiv.com/system-status-parameters-guide/
Thanks for the reply.
I haven’t been using the tagdiv composer so I wasn’t using both at the same time.
I did a test page using the single image using tagdiv composer where the heigh settings work but the image isn’t responsive to different screen sizes, it just gets cut. Any settings I’m missing?
Going back to text block – I believe in tagdiv composer, its not column text.. When I tried adding an image and it did not go full width. The text did.
Sample here: https://rmn.ph/test-ad/
Try as a test to deactivate all your plugins except the tagDiv composer, and clear you cache afterwards. Then create a page and place the element you want on it and test again.
Using the image that you are in the image box
– https://www.screencast.com/t/HLOAzhxhfh
These are the results I get
– https://www.screencast.com/t/s4qsEWvm3n1l
– https://www.screencast.com/t/OmeNtgqgSbf
Same problem here. Any solution? Responsiveness and links are not working.
@corridaurbana
Please provide a link to your website and more details as to where this is happening, so we can see the problem. Nothing has changed regarding the theme responsiveness in the latest update.
hi, td composer is quite slow and the nav on the left gets cut.
On a default theme install, using only the plugins included in the theme package,there is no problem using the tagDiv composer. Both in terms of speed and design or display.
This can be caused by not having the system status as mentioned in the guide provided by Bogdan
Or maybe a plugin conflict. Try testing with all other plugins deactivated, and also clear your cache after you disable them. See if there is any effect after doing this, and let us know if you still have problems.
sample post using the image confirmed that it cuts it and doesn’t follow the proportions. switching back to visual composer until this gets fixed.
