Images left spaces between celds
Is any way to set a image to use all the space of its celd?
Spaces at header images???
Please make sure you upload images that are larger than the container you want them to show up in.
And then use this guide: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
Done, and the images are still showing the same error. The images are big enough: The left image (SmartHalo headline) is 1.599px × 715px.
PD: Btw, is cells, not celds, my bad, sorry (Not maternal language).
Please provide a link to your site so we can inspect it.
Please also try to disable any image optimization tools you might have on your site.
Go to https://tech.luisetef.es/ and click over the lock in the right. User “” and password “”.
Then you will see the homepage with it!
  • This reply was modified 9 years by Bogdan B..
Your site does not use a thumbnail for images but rather the full image: https://www.screencast.com/t/8iDWOi9xa It cannot show up properly without the thumbnail. Please make sure thumbnails are active in the theme panel: https://www.screencast.com/t/bsiDuPK5F and regenerate your thumbnails afterwards.
Thumbails were already activated since day 0. Block shows text error if they are deactivated. I deactivated them, reactivated and regenerated the tumbails and it keeped at the same status.
Can be it related to .htaccess / Rewrite conditions module config? Can I send you Virtualhost-htaccess files (very small) and if you see something you give me the heads up?
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
Bogdan B
