Images not showing on post
Hi there,
Great work on the theme, I have been using this theme for a client and it has been working great. Over the last couple of days I have noticed posts have not be showing images randomly. All post have an image and sometimes show and sometime do not. Every post has an image display when you view the post, just not in thumbs and the box grid box and the recent posts list.
The website in question is http://www.fft.ie.
Have you come across this problem before?
Thanks in advance
Try disabling the lazy load option as first step.
Thanks for the prompt reply Chris, is the lazy load option the theme options panel?
I think it might be under ‘templates’ .. don’t remember 🙂
Thanks Chris!
Hi kwealleans, sorry for the delay, unfortunately the forum was not functional for a while due to some technical problems, sorry for that!
I’ve checked your site and found it working fine now: http://screencast.com/t/PbTRlC4X so I guess you have managed to solve your problem.
Please let me know if you still assistance on this and you can find the lazy loading animation option in theme panel > template settings: http://screencast.com/t/etwmkpZp5
