Images on blocks are not loading in mobile
Hey guys. Images on blocks are not loading in mobile. See here >> https://prnt.sc/jkekgz
my website: https://techlandia.com.br
See here in mobile*: https://prnt.sc/jkel1v
Hello leanjucas,
I have inspected your website and I saw that you are not using Featured images for those posts -> https://www.screencast.com/t/7DLFt1Xu and that’s why you do not bring any image on the block and also, I have noticed that it could be a temporary problem with your opacity for the others images. Maybe your images are stuck in opacity 0. This usually happens on a js error caused by plugins or customization or other external optimization tools. Please disable all plugins except visual composer, clear cache and reset CDN files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functioning of the theme.
We recommend using our TD COmposer because all of the major improvements in the future will be made on this plugin.
Apparently it worked. Thank you! Featured images was disabled. I think I did it without meaning to.
