Images problem
Hi!
Have some problems with loading images.
Screenshots
1
2
How can I fix it?
Thanks in advance.
Seems some of the images cannot be loaded, there are mixed content errors
– http://prntscr.com/md3bhx
You could check some guides in how to implement HTTPS for the website
– http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
– https://css-tricks.com/moving-to-https-on-wordpress/
– https://yoast.com/dev-blog/move-website-https-ssl/
– https://forum.tagdiv.com/topic/moving-to-ssl/
Hi! They are not loaded only in “related articles” and “Search” places of Newsmag Widget. Everywhere in another places is ok and my website and images has https settificate. Are you sure, that problem is in SSL?
That’s how it looks – http://prntscr.com/mdlbgr
The favicon image is also not loaded, also a script from a plugin it seems
– http://prntscr.com/mdldtf
You could give the plugin mentioned in this guide a try, see if it fixes the problem
– https://www.wpbeginner.com/plugins/how-to-fix-the-mixed-content-error-in-wordpress-step-by-step/
